E8400 On showing as 2Ghz in CPUz
14 Feb 2007
Why does my E8400 only show as 2ghz 333*6 in CPUZ. Also my Corsair Dominator Memory only shows as PC6400 not PC8500.
Motherboard is an Asus P5Q
Graphics card is a Asus 4850
3DMark06 score was 10600ish does this sound correct.
Thanks
You have speedstep enabled which is running the CPU in powersaving when its idle hense the lower clock.. if you load the system you will see this jump back up...
I would imagine you are looking at SPD in CPUz which is giving you default values for the RAM... I shouldnt worry shows my OCZ as PC6400 not PC9600
depends on the board.. Asus boards dont decrease vcore on the down step so it doesnt cause instabilities when the system is clocked.. other boards do and you might find it does therefore cause instability..
I clock with it on.. as your running a Asus P5Q I dont see it would do any harm keeping it on
Doesn't that defeat the whole point of speedstep if it still uses the same voltage while underclocked???
I do believe its only when you are on manual clock settings.. (might be wrong there)
IF your using EPU engine then it does.. but you cant clock with that on
I see. So lets say I wanted a little overclock to say 3.2, I'd go for a fsb of 355 (I'm guessing the standard mulitiplier is x9), but the speedstep drops this to 6x, so at 355fsb the speedstep would step down to 355*6 2.13Ghz?
Is that correct?
well technically higher FSB gives better performance (not real world noticable) but 400 * 8 is preferable to 355 * 9 as 400*8 will allow you to run PC6400 RAM in a 1:1 ratio at its rated frequency
Edit:
Although if you have a divider that will allow you to run the RAM @ 1066 = 355 * 3 then that is actually the better option for 1066 RAM (sorry thought you hade PC6400)
Cool thanks for explaining.
Might have a play later. I'll goto 3.2 for now as I've only the stock cooler. Will the E8400 go to 3.6 with out getting into voltage changes ect
Hopefully some body can give me some pointers here. I tried to clock my system, but each time it failed too boot.
I entered a fsb speed of 355 to get 3.2mhz. And also manually set the multiplier to 9, disabling the speedstep.
This adjusted the Ram Speed automatically, So I selected a speed of the ram that was lower than the 1066mhz its rated at but still no joy. I'm probably missing something very simple here. Any ideas
