Antec P182 and longer Corsair 1000w PSU?
22 Jun 2004
London
Howdy,
I'm planning on building my new system soon, and I've opted (so far) for the Antec P182 Super Midi Tower Case (http://www.overclockers.co.uk/showproduct.php?prodid=CA-070-AN) and the Corsair HX 1000W ATX2.2 Modular SLI PSU (http://www.overclockers.co.uk/showproduct.php?prodid=CA-012-CS)
However, the Corsair HX 1000W is longer than most lower wattage PSU's, and I can't find any images on the web of a P182 using one of these PSUs, will it fit in this case? The Corsair is 2000mm long, and by the looks on the case images, there seems to be a cage that houses the PSU... but not sure if it allows the PSU to slide beyond the end of the cage (that is hard to explain)?
So basically, will a Corsair HX 1000W ATX2.2 Modular SLI PSU fit in a Antec P182 Super Midi Tower Case
Any help will be appreciated!
ta
There is a little cage for the PSU, I haven't put mine on, I don't think there is any need to either, plus it looks better without it.
I think you mean 200mm, not 2000mm, and I think you would have to take out the bottom fan for it to fit (Based on a 200mm PSU)
