It could be
this problem that affects nearly all of ATI's range of cards. Some people get it, but most dont. Hope it isn't that though 'cause theres nothing you can do to fix it if it is... believe me i've tried.
Does it ever just crash to desktop?
Sorry to take so long to respond to this but to link to that thread is a joke & is no different than some people getting BSOD in windows & saying there is nothing you can do about it, but this is the BSOD for gfx cards.
This problem also effects nearly all of the NV range as well unless your saying that there is a range of NV cards that have never crashed for anyone.
Its swings & roundabouts & the most popular cards at the time will get more hits because there is more of them unless there is a fundamental flaw that will make headline techs site news if there is one.
High failure rate over heating chip on one of the NV 7xxx series.
Wrong resistor/bad soldering on some early NV 8xxx/ATI 3xxx cards...ect...
Noticed that there are a few 260/280 threads will the same problems as the 4xxx popping up on this forum now.
There are people on this very forum who had the same issues as you & have fixed it.
But you have not mentioned or pointed to a possible solution & the best you could do is basically say your stuffed.
Some being a conflict with the hard drive shutting down & starting up again in vista, Non upto date BIOS ,On-board sounddriver , X-fi driver & NIC driver killing the GFX card drivers.
