Just dont expect it to run super fast, and play games well lol.
Agreed it will / Does run perfect with 1 gig of ram
I've got a celeron 430 (1.8) and 1 gig of ram running W2k3S working as an internet gateway/router/content filter/bandwidth management also serving video/MP3 and the printer for 4-6 machines.
it runs great so there's no reason why you eeebox with similar spec shouldn't do the same.
EDIT : Before you think about linux you need to check for printer compatibility, as this was my major downfall
I don't quite know where you get the dumb terminal from?
lol you can even set it to send magic packets to turn on your PC's when your connected from austrailia for example
google wake-on-lan and magic packets. if you go to device manager and look up your network adapter and go to the advanced tab there should be a wake on lan section or wake up capabilities. just set it to accept magic packets and just use any free app on the net to send a magic packet it to the pcs ip address when its turned off, and it should turn on.
this has only worked for me on the internal network so you can't for example do this from yer iphone from halfway across the world, but if you login to your home server should be fine.
But does this work over wifi?
