360 headset on pc works but how do you activate it?
12 Oct 2003
I have an audiophile 2496 and as it doesn't have the right connections for a standard mic headset i tried using the wired 360 controller and headset which works in the hardware test but i don't get how im supposed to activate/route it to actually use it, as its a usb audio device im not sure how this works differently, i just want to use it in general like a normal mic, i played around with ins/outs in the mixer but no luck even though it works fine under the test and is selected under both recording and voice, appreciate any help, thanks.
Are you using XP or Vista?
I'm not aware of how its done in Vista, but in XP, if you go to Volume Control > Options > Properties and change to your recording channel. Once there, under "Show the following Volume Controls" find one that relates to your 360 Handset/Headset.
