Chasis USB ports - Don't Work
20 Aug 2008
Hi i have a CoolerMaster Stacker 832.
I am using an Asus M3A32-MVP DELUXE MotherBoard
I have plugged in correctly I have triple checked. None of the front panel USB connectors are working. Any suggestions?
IIRC cables to motherboard's pin headers have connectors also in other ends so you should check that those haven't gotten loose.
I think he means check that the USB cables from the case are connected to the correct pins on the motherbaord and are making a good connection.
Check also your USB controller.
CLick Start, Run and type in devmgmt.msc
Ckec for any exclaimations marks under the USB controller (last in list).
i ahve had the issue before with trying to strech the wire too far while cable tidying and pulled it out the front connector, not noticing until you finish your whole pc and then cant get to it is fsking annoying lol
i have plugged devices on the back of the motherboard and these work fine.
I then try and plug the same devices in the front panel connectors and i dont get the "Du-Ding!" sound
