Bucket Seats
:confused: its not selling, he should be asking his uncle if hes got some STi/WRX seats in, so i can sneak down at nigh...forget that bit, so i can go buy one, and build a Pc chair, and show you guy!
Ive deemed this to be Motors area, were can i get a cheap tastefull bucket seat, Demon Tweeks is too expensive, i want to make a PC chair out of it :D
Hello azab350
If you want a bicket seat then yes they are generally available for £50 or so second hand. They do not wear particularly well and will likely be stained and in relatively poor condition. New ones are roughly £100 for the cheapest OMP and Sparco ones.
you do realise you can buy office chairs already in the form of bucket seats? im sitting in one right now.
I will leave it thanks, and if i do that i will have to reveal my identity to you.
eh.
offering to help somebody finding something, then ask whats in it for you, then decide this isnt enough, then come out with stuff like this
you been smoking something ?
Found a cracker on the-bay, just waiting to see if hell sell just 1 of the seats, not both..
Branding the other seat useless. Good luck with that.
One in a well known high street catalouge shop in leather, bucket seat like for £100.
try Grade A Subaru if you want a Subaru one, they might have an odd seat, but they do generally sell whole sets.
Think he meant the 550 ones.
Either Makro or Costco do cheap buckets apparently, or they used to anyway.
It's not McGinleys, it's McGuinness's or "Gintos" if you're from around these parts. :)
Was down there not long back looking for some plug leads for an old Vectra.
Not normally the kind of place to get bucket seats from. Also the guy on the door makes up the prices :p
