hi
i need some help with freekicks , ive tryed the L1 plus shot button ,but it keeps hitting the wall , what am i doing wrong ?
cheers
This is going to sound ridiculous but, you're either using too much power that your kick taker can't control it... or you're not using enough and he can't get it over the wall.
With the LB/L1 shots you need to remember it's a "power freekick" so it's going to be faster paced than a normal freekick anyway - with little curl.
There should be notches on the powerbar for the freekicks, you've got to generally aim at getting it just over the second notch on the power bar.
It's a difficult skill to do power freekicks all the time, and depending on the walls position it's even harder.
Don't always rely on LB/L1 style freekicks, the regular curling freekicks are there for a reason. If you don't think you can get it up and over the wall, bend it around it.
You'll need to aim a good foot or two either side of the wall for it to work, and push the stick in the direction you want to curl it while powering the shot to add the curl.
Remember that pushing the left stick while powering the shot adds to the balls curl when it leaves your foot.
Pushing forward means the ball will fall very quickly from the air.
Pushing back means it'll stay up in the air longer.
Pushing left curls left.
Pushing right curls right.
Pushing diagonally Up+Left makes the ball curl left and come down quickly, Down+Right means the ball will curl right and stay in the air longer...etc...etc...
