After my recent attemp at buffing out a few scratches I decided to look into getting a polishing machine! I can actually get either of the following very cheaply through work (well the price of a few pints to be precise!) and was wondering if they would be suitable for use on a car as I'm not sure if you can change the heads on them? Think I might not be fully understanding the terminilogy as it talks about back plates but if anyone could confirm then that would be great.
Draper 44190
http://www.thetoolboxshop.com/44190-1500w-230v-draper-expert-180mm-angle-polisher-5108-p.asp
Sealey S0758
http://www.justoffbase.co.uk/Sander-Polisher-180mm-Variable-Speed-1200W-230V-Sealey-S0758
Also if I can use different heads a link to some I could buy would be very helpfull too as there appear to be quite a lot out there. Or are all the "decent" brands much of a muchness?
Thanks
Draper 44190
Sealey S0758
Thanks
