I have setup a number of Q6600 rigs and non of them have had issue reaching 3.4ghz.. That is ofc on 1/2 decent motherboards.. I would be very suprised if on a P35 or better board you couldnt get a Q6600 to 3.4ghz with adajuet cooling
The chips are not tested so the guarantee is worth nothing.
Although reading some of the posts in this forum, some of the later Q6600's seem to be struggling to reach 3-3.2.
This is not correct. If the chip doesn't clock to the specified speed, it can be returned for another - not something you can do with a standard none guaranteed chip.
Indeed, these later chips don't have the same overclocking ability as the earleir versions (generally).
yes.. but there must be an limit on how many times you send it back. because it'll be silly if your keep sensing it just because it doesn't clock to what u want..You can return a standard chip as said earlier via distance selling.
as i said before it's like saying ummm i'll get a 50" tv so i can enjoy these movies for 5 days then send it back. then do same again next time.
My mate has an asrock board, id like to see him get a guaranteed overclock that needs more than 300FSB
its really quite simple....
The chips are known to be capable to overclock to xxxx, therefore, for the miniscule portion of chips that dont, they are prepared to take a loss on them.
Therefore you may aswell just buy the standard chip, and if you happen to be very unlucky, like one in 100000, then you wont be able to OC it quite that much.
its like q6600's.... they will ALL OC to 3ghz+,
so buying a chip thats guaranteed to OC to 3gz is kind of silly.
thats like saying ummm i'll get a 50" tv so i can enjoy these movies for 5 days then send it back. then do same again next time.
Yea but with the distance selling reg you can send it back, they don't need to know that.
You ain't going to say, hi I watched 5 movies and don't want the TV now so I'd like to send it back thanks.
Overclocking does not void your warranty. Only time your warranty is void is if you remove the IHS or it melts. Official statement from Intel. I will find the link and post it here for the proof
