Hi all,
I wanted to buy a new PC but my budget is pretty small
I have come up with the next PC and was wondering if anyone sees any problem or incompatibility. That would be soooo much appreciated guys... I have added the links to OC web pages just in case it is easier:
Motherboard: Gigabyte GA-MA770-DS3 AMD 770 (Socket AM2)
CPU: AMD Athlon 64 X2 Dual Core 6000+ 3.00GHz (Socket AM2)
Memory: OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Dual Channel Kit
Graphics card: Gainward GeForce 9500 GT 256MB GDDR3 HDTV/DVI
HDD: Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache
Case: XClio Coolbox Midi Tower Case - Black (No PSU)
PSU: Gigabyte SUPERB 460w PSU
As you may imagine I don't want a gaming PC, but there are a couple of points that I am not really confident at and that would be very grateful if someone more experienced and wiser could give me some advice:
- Will the memory work at 1066MHz properly or downgraded to 800MHz?
- Is it really worth it a graphics with 256MB GDDR3 instead of a 512 DDR2?
Thanks a lot in advance guys, much appreciated!!
