Waking PC from BIOS
18 Oct 2002
Royston, Herts
Hi all,
Here is my issue. I get free broadband from 2-7am and I want to take full advantage of this. However, I don’t want to leave my PC running until 2am (when I usually go to bed around 11pm) as this is just a waste of power. So, what I’m looking for is a way to automatically start up my PC at 2am. The rest of it (starting the programs and shutting down I can do already with freeware on my PC).
The motherboard is a PC Chips A33G running WinXP Home (fully updated). I have been unto the BIOS and Activated ACPI and set the RTC to resume on RTC alarm (which I set to date and time). Result: Nothing.
Any ideas what rudimentary mistake I’m making? 
If you set your programs as a scheduled task, doesn't it wake and run them? This works on my HTPC when it's recording TV, updating AV etc.
Sorry to ask a stupid question but you're putting it into standby right?
Yes to standby. My problem is that the PC doesn't start. Once into Windows I'd be OK. The problem is that I can get that far.
Are there any power state options in the bios like S1, S2 etc?
What about options to wake from USB, PCI etc?
Wolvers69, I'll have a play when I get home. As a matter of fact it doesn't wake from stand-by from keyboard/mouse. I usually have to hit the power button to get it to boot.
Look in the BIOS, Power Management Setup page.
Set 'Resume on RTC Alarm' to Enabled and then configure a time for the system to turn on.
Try it with no date set.
Resume On RTC Alarm
The system can be turned off with a software command. If you enable this item,
the system can automatically resume at a fixed time based on the system’s RTC
(realtime clock). Use the items below this one to set the date and time of the
wake-up alarm. You must use an ATX power supply in order to use this feature.
Using a combination of enabling/setting the RTC time/date and a freeware program called WakeUpFromStandby I was able to get the system to boot itself 3 times yesterday whilst playing around. Satisfied, I went to bed after setting to to wake at 2am. Result: It didn't turn on but sat in standby al night uselessly. :(
More investigation proceeding tonight.
My mobo (Abit IP-35) has a bios setting which starts the computer automatically from a total powered down state (does not need to be in standby) Set this for 01:45 so it has time to start and then set your tasks to start from 2:00pm.
Cheers
