Do you reckon it's easier to rank up RR at the same time as EXP? So far i'm keeping my RR at 1:1 with my exp rank, but it's time consuming. Would it be easier to level up then go back and do RVR for Renown?
It depends how you level, if you're doing lots of scenarios you'll find that they'll stay relatively the same levels since your gaining lots of RR at the same time as Exp for your Ranks.
Doing Keep raids with guilds and defending keeps will give you huge RR boosts, I went from RR11 to RR14 on Saturday and all we did was a keep raid, some outpost captures and battled destruction for ages
Personally, as long as your Renown Rank isn't hugely off your level I wouldn't be too worried. If it starts dropping say, 4 or 5 levels off then start trying to boost it.
Before Saturday I was level 16 and my RR was only about 10 or 11, I was noticing I was picking up quite a few items that were for my level but I wasn't at a high enough renown rank to use them. So when that starts happening, get worried!
