hi...
so saturday, had the bright idea of formatting my pc as it had about a years worth of junk on it and wanted a clean install,
I have vista 64 oem version.......so i insert disk go throught the reinstallation process....delete partiction and install vista....pc crashs during install.....this happens several times.
I changed my usb k/b and mouse for an os one crashed during install again.....read somthing onn the internet about the amount of ram ..so took out 2 gig of the ram i had in so i only have 2 gig of ram in,.,,,
install goes through fine.........however.. when my pc starts i have a screen which asks me to choose the op system which i want to use... there are two of the half intalled versions there and the one which works....
also there's a copy of xp ( i got sick and tired of installing vista after about 5hrs and installed a copy of xp to delete the partitions) - btw I have 2 hard disks, it appears that the half installed versions are on the hard disk which i didn't want to install vista or xp on....
so i'm left with a pc which has a working copy of vista and 2 half corrupt versions and a version of xp - .......how on earth do i get rid of the 2 corrupt and the xp - i tried going and deleting the partitions (on my second disk)and formatting with the vista disk, however it does this and then boots and i get error msg - you need to insert system disk and press enter....then change the boot sequence to the other h/d and i get the choice of the op systems again, which i thought i'd got rid off.!!!!
any ideas? short of starting all over again.....
