- 29 May 2005
- West London
ah just phoned o2 upgrades, X1 being released this week, on a side note the C905 is on 20th
Yup, stock is coming in today
How the heck are you using more than 2Gb on emails?!? Youd have the be constantly sending them or have massive attachments with them...I use way over 2gb per month (on O2) but never got any messages telling me to stop or been charged extra. Then again I use it for emails purely and not much on browsing and I have been with them for many years and probably spent enough to buy a brand new car.
I spoke to O2 again today and they said sometime this coming week to taking orders. I will phone them again tomorrow.
ps3ud0![]()
Yup, stock is coming in today![]()
Any one know if T-Mobile will be getting this?
- Did you buy it Simfree?
- Does it use the standard WM6.1 email client?
- How is the reaction of the keyboard? XDAs have a problem sometimes of lag between pressing a key and seeing on screen
- General speed?
Does it have :
1) Hand-writing recognition?
2) Geo-tagging of pictures?
3) Ability to use only one hand to text? (one-handed-texting)
4) Can it take an 8GB microSD?
5) Can it essentially be used as a mini-mini-laptop?
6) Can you browse the web using wifi for free? (on my home WLAN)
1) Does it get sluggish over use? Once you used a few progs and shut them down and returning to it later...
2) How well does it come out of standby?
3) How representative are webpages on the browser compared to a normal full-fat browser?
4) Picture quality? Both in normal daylight and in poor light conditions?
5) How hard is it to upload a photo you have taken to Imageshack?
ps3ud0![]()
Can you tell me where you live so I can come to your house whilst you sleep and steal it from you?
is opera the java one (uses their server) or the 'beta' like on the diamond?3) Browser is Mobile IE, which is useless. Also comes with Mini opera, which is great![]()
Ahhh so you are using it without any network bloat - probably helps a lot...
With regards to uploading a pic, on my Vario 3 its a nightmare as when using IE the folder where photos are saved isnt browsable so you have to move the file first before you can find it :/
How stupid is that
Hoe do you compare it to other similar functioning phones?
ps3ud0![]()
