Want to spray my brake calipers red.
28 Oct 2006
Cambs/Florida
Hi all I want to spray my calipers red on my motorbike is it just a case of take of drain of any brake fluid and spray them. Or do I need special paint todo so?
thanks phil.
Hammerite will do the job, you'll have less work to do with a brush too. Spraying you'll have to remove the calliper, possibly strip parts from it and mask up.
Hammerite smooth red does a nice job, too.
Black or silver imo.
Silver needs freshening up frequently though. So mine next time will simply be painted black.
if it's paint then black or silver, so the rubbish finish isn't so noticeable. If you want a colour then it has to be powder coating to get a good finish
I guess I shall leave it standard then, I thought it would look alright, you never know till you have done these things!
Chears Phil
