- 26 Sep 2005
- Midlands
Your P5N-E Sli will clock your E6600 fine with a Freezer 7 Pro. You do not need a new motherboard or cpu. Once your E6600 is overclocked from stock you will see a big performance boost. Can't remember seeing it, but have you said what graphics card you already have? I suspect that judging by the rest of your rig maybe a 7800/7900 series or maybe even a early 8800GTS 320/640mb? If so then changing to a new 4800 series or GTX 260 will be a big upgrade.
My current graphics card is:
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
I have a thread in the Graphics Card forum also and someone recommended this:
MSI ATI Radeon HD 4870 X2 2048MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Not really an ATI fan due to experiences in the past, but the general consensus is that they've improved a lot recently. So would the above mentioned graphics card be ok? And shouldn't be a problem with my current motherboard?
So with my Freezer 7 Pro, what sort of level would I be safe ramping my CPU up to? I like to skirt just below the maximum recommended
Yes, then it would be worthwhile. More importantly, you will definately need to clock that E6600 to get the most out of a 4870x2.
