Caporegime
- 11 Mar 2005
- Leafy Cheshire
A lot of people don't realise that ESP will always try to point the car in the direction the steering wheel is pointing, if you manually try to correct a slide ESP can then direct you straight towards what you are trying to avoid. It does look like what happened to this guy.
Aye, had it a few times in mine (minus the 4wd cutting in) instinct tells you to correct but if you do it makes things worse, i had a play on the gravel at donnington with varied results
As I have said when you loose it at proper speed you need skill, luck or both as electrics are going to fold their arms and say "over to you".
