I paid 4 quid inc delivery I believe and it works perfectly![]()
Good sound quality through VOIP? (Ventrilo/TS etc) ?
sorry for not elaborating more, was just waiting for steam to open when i checked the forums for a sec..
goldring 100 or 150 with that soundcard will be awesome
Will place order soon, many thanks for the help.Ok, thanks for letting me know that, will probably go for headphones instead then.
At the moment it looks something like this :
http://www.overclockers.co.uk/showproduct.php?prodid=SP-001-GR
http://www.overclockers.co.uk/showproduct.php?prodid=SC-002-AS
http://www.overclockers.co.uk/showproduct.php?prodid=SP-016-LG
But I'm not sure whether I should go for a clip on mic instead?
This is exactly what I've got, a brilliant setup. Those headphones with the xonar are excellent, probably the best you can get in your budget. What motherboard is it you have? It'll probably have a PCI-E X16 slot and a PCI-E slot, the X16 being the one where you graphics card will be. If you give the model of motherboard you have we can work out if it'll work.
basically all 'gaming' headphones are crap
getting 'proper' ones are a much better idea, the Goldring headsets were added to ocuk due to popular demand. couldn't remember the name of the mic, Hutch said it though, personally i just play casually so don't bother with voice comms (plus my gf would disown me i reckon..)
Why even bother with a soundcard when you can just get a USB headset which works without one? (asuming you are always going to use the headset and not speakers here)
