Updated Bios - Now it won't bot over 400FSB!
6 Apr 2004
Bath, UK
Just updated my BIOS from F7, to F13 - which solved a few niggles i was having. However, it won't boot past 400FSB now! I save to bios, it turns off, turns on, turns off, turns on and disables FSB option so its back to normal, no other settings change.
Specs are
Gigabyte GA-P965-DS3
E6300
OCZ XTc SLi PC8500
520w OCZ
Any ideas?
Thanks
Are you building up in stages. Some boards won't let you make a big leap in one go.... might have to build up to it.
Otherwise check you're other settings... as they may have returned to defaults following the flash... eg , memory, NB etc
AD
when you have updated the BIOS makesure you clear the CMOS or it can cause issues like this
just what i was going to suggest
only board i have used where this isnt the case is my current asus which has the EZflash utility [which is brilliant imo]
