How much of a performance boost could I expect to see going from an 8800GT to the GTX-260? Worth making the leap now or better holding off for 6 months or so?
I also notice the GTX260 is listed as being PCI-E 2.0, would this mean it may not be compatible with my present motherboard?
are you finding anything you can't play on your 8800gt? The 260 would be a good jump but if you're not struggling it would be worth holding out for a little longer. Moreso if you only play at 1680 x 1050 and below.
