Yup... Android has arrived. Read the full review here: http://www.engadget.com/2008/10/16/t-mobile-g1-review/
Interesting snippets:
So some good and not so good things then. Will be interesting to see how the platform evolves over the next 6 months and beyond.
I think i'd still prefer a Tube though...
On the keyboard side, the physical layout here is generous to say the least. Clearly a lot of thought went into making this QWERTY usable, and usable it is. While the keys aren't especially raised against the backing (in fact, they're nearly flush), they are fairly responsive and widely spaced, making two-handed typing a breeze. The placement of the "chin" does get in the way of speed typing at first, but once we figured out how to avoid over-extending our right hand to get to certain keys, it became less of a problem. Alternate key characters are distributed in a reasonably sensible fashion, and you're provided with another "menu" key on the left side, though we rarely found occasion to use it. We had a little bit of re-learning to do going back to physical input after using the iPhone, but once you get the hang of it, this keyboard makes dealing with lots of email or IM sessions a breeze. Our biggest gripe on input? The keyboard is the only way to interact with text on the phone. If you need to send a quick SMS, you have to get the keyboard out. This can be an incredible pain sometimes...
Along the bottom of the phone is HTC's totally meaningless ExtUSB port, which actually can accept micro USB plugs. Why we're forced into this odd connector type and denied a 3.5mm headphone jack is beyond us. We were told at the phone's launch that there would be an adapter included with devices (at some point) to allow regular headphone use, but honestly, who wants another adapter to worry about? Something tells us that if you're buying a phone that's supposed to "do everything," having to fiddle with some janky piece of plastic just to connect your earbuds is going to get real old, real fast.
As we said above, the display is a capacitive LCD touchscreen. At 320 x 480, it's the same resolution as the iPhone, though the pixel density is slightly tighter here due to the smaller size (3.2 inches). Overall we found the screen to be outstanding. Colors are bright and vibrant and both text and graphics display crisply, helped immensely by rich, deep blacks. While at full brightness it's still not as stark as its nearest competitor, that actually turns out to be a plus -- this strikes just the right balance and is very easy on the eyes, even in low light. The choice of capacitive touch is a godsend. We were worried HTC would punk out and throw another resistive screen our way (hello Diamond and non-capacitive-compatible Windows Mobile!), but they pulled out the stops and it pays off big time.
As far as the hardware is concerned, the 3.2MP camera itself has some great and not-so-great features. On the plus side, the lens actually focuses and can snap fairly close shots, allowing for near-macro pictures depending on conditions. It's a great touch that we found lots of use for. On the other hand, due to that slow refresh and really, really mushy quality of the camera button (as well as awkward placement along the edges of the keyboard and body), it's hard to know what you're going to get. We ended up with plenty of blurry and totally unusable pictures. Additionally, performance in low light was abysmal, rendering grainy shots that were practically useless. In good light performance was greatly improved, but in comparison to other phones we had around, the results were fairly disappointing overall. If you're looking for some kind of digicam stand-in, forget about the G1... taking pictures is definitely not the phone's strong suit.
