Hello,
I am in the middle of specing my first water cooling setup, i have not included the CPU and GPU coolers yet as i am waiting for the new Intel CPU and have not decided on GFX yet.
Please advise if all is ok with this spec:
Feser TFC Xchanger - Triple Radiator 360
Swiftech Laing D5 Vario MCP655 12V DC Pump
Masterkleer 7/16" Tubing - 2m
8 X EK 1/2" Hose fitting
XSPC Single Bay Reservoir - Clear
Feser One UV Reactive Coolant 1 Litre (Acid Green)
I'm planning on putting into a Coolermaster 1100 case (I know i will need to do a bit of modding as the radiator is a tight fit). Anyone else running this case and rad?
Thanks
Thanks
I'm using 7/16" tubing on 1/2" TFC fittings.
