My 50mm and little girl!!
8 Mar 2007
between here and there
just got my grubby mits on a canon 50mm F1.8 yesterday, got in from work and shot a few frames.
Just thought I'd post a few. As usual don't be afraid of hash criticism as it be the only way I'll take better pics in the future.
1, - DOF is a little shallow, should have up'd the F stop slightly
2,- A bit noisy that one. but I like it.
3, - Seems soft to me, but it was rushed and without any IS on the lens I need to hold the camera firmer??
4, - I don't know why, but I like it. I know the door frame in the background isn't anywhere near straight but still... :)
Let me know what you think.
yeah, the light in my front room really isn't great. To be able to get a sharper shot I up'd the ISO for a faster shutter speed.
Shame.
Crop it and maybe turn it to B&W and I reckon you'd have a winner :)
A quick example:
I bought a nifty fifty recently too, am having great fun chasing the dog round the garden trying to get some shots!
Sorry but it's not the DOF as all of them are out of focus to me - looking at the EXIF on (1) you had 1/40 sec which is not fast enough to freeze the subject and get a sharp image.
The general rule for stable image quality is: use a shutter speed faster than the focal length of the lens. For example a 50mm lens would need 1/50 sec shutter speed on a full frame dSLR. Now as you have an APS sized sensor at half the size of full frame you need to multiply by 1.6. So if you use a 50mm lens, the actual focal length of the lens when used with your dSLR is 1.6 x 50mm = 80mm. So again a 1/80 sec minimum with steady hands.
Better light will help you keep the ISO lower = less noise, but make sure to keep that shutter speed up.... I hope that helped & look forward to the next shots.
Wow, thanks. thats some really great advice, I'll bear that in mind.
I'll have another go tomorrow and post back.
cheers again! :)
