As has been said the standard crosswind landing technique is to fly the aircraft with the nose into the wind, so that the aircraft is actually tracking the centreline of the runway. This can be quite a large angle if the wind is strong, and so it can look to passengers like we are flying slightly sideways. When we get close to the ground, around 20-30ft (depending on the aircraft type) we will start the flare, which means pulling up the nose a couple of degrees to reduce the rate of decent from around 700-800 ft per min to a nice gentle descent to allow for a smooth touch down (again depending on the conditions, somestimes including crosswind situations it can be beneficial to make a 'solid' landing to make sure that we retain positive control during the touchdown) Whilst flaring at 20ft or so we will kick the nose straight down the runway so that the main gear will touch down straight. Sometimes to keep the aircraft where we want it on the runway we may need to drop the in-to wind wing slighty, which can be a little uncomfortable for the passengers, but its all very standard however.
