Any case studies showing Vista sound better then XP?
18 Oct 2002
England
Long title I know but one of the reasons ive found myself sticking with Vista 64bit was the apparant sound/graphics improvements and the 4gig+ ram barrier, but I just wanted to find out if Vista really did offer better "sound" quality in say mp3/flac/games etc
Sound or Graphics cannot be improved by the OS, Even DOS can output the same quality sound as XP/Vista, its all in the compression used and the Player, DOS can play raw WAV files which is the closest the PC can get to the Analogue source. With good programming DOS can even out do Any Windows OS when it comes to Graphics its just that Direct3D and OpenGL have made windows the easier option.
Older games? I'm a today gamer, I play older games in the olden days and move on! Vista sound is good on my Xonar D2x :)
do you get all positional sounds as expected? (i'm not challenging you with a sarcy post btw) with smooth left and right sound changes?
in vista with my xfi, i had to use 'alchemy' but it was still weird with that..
alchemy is a crap way to deal with the problems by creative
might get a xonar if there's no issues with any games in vista
I only have 2 speakers so cannot comment on 5.1 but I can test for you in stereo ;p
Max Payne 1 or 2 ?
max payne 1, using headphones here (so stereo)
with the xonar, do you have to run any software to get all games effects working properly?
the xfi really rocks in xp, but is far from complete in vista games
I had no troubles with them last time I played but will confirm when i get home after work tonight :)
cheers
when i've got a better gfx card and 24" screen (that can play at dx10) i'll consider replacing the xfi too then
atm i've just got an 8800gt, so there's no point in upgrading my gaming rig to dx10
I haven't played it on the 24" yet so should be interesting to see how it looks!
Ok Just had a quick play after reinstalling and it seemed perfectly fine, in fact no different sound quality wise to how I remember it!
thanks mrk
i'm considering getting a xonar for my vista media centre, will check my funds (and will test the card in both machines) :)
You gotta be crazy to not be impressed by the Xonar :p I certainly was! and I had a Turtle beach Santa Cuz back in the pre-Vista days! (then got an XFI for games)
I did have the Auzentech HDA Xplosion after the XFI briefly though but it sucked in games whereas the Xonar is great in games!
