PowerColor HD4870 1GB - It is a two slot card isn't it?
powercolor uses simple cooler i think.
edit: actually i dont know i will post when i get mine
it might come with this cooler
i will post picture when get mine tomorrow or today
I have the Powercolour 4870 1GB from here.
It is dual slot and vents the heat out the back.
I would say the one you pictured is the 512
That's what the pictures on the Powercolor website seemed to imply!!
I ordered it about an hour ago, so that's a relief!
So the image on the OCuk website is correct!
Yup I can concur. This is correct. I've had the 512Mb and currently the 1Gb from Powercolour. They are as in the image. :)
