alternatives to watercooling tubing?
rjk
rjk
OcUK Staff
8 Aug 2007
hi - i have spent the past few days [and a great deal of pneumonic's time ;)]
looking for some white gloss tubing for watercooling my rig
i originally wanted black tubes with gloss white coils - the coils were a no go as i coulnt find them
so after seeing a nice build from another forum that pneumonic linked me to i decided that white tubes with black coils would be alright too
problem is
i cant find any white tubing apart from dangerden and its not the size i want
so im asking - could i use some other type of tube [that is white]
[one that is not made for pc watercooling - but would do the job?]
it seems that everything is good as long as you want 'generic gaming pc uv blue'
anyone suggest anything in 1/2" or 7/16" ID
[if you could find a brand of anti kink coils in gloss white to suggest that would be brilliant]
just use 3/8" i know the other pc you refer to he had the same issue and had to change his rig to 3/8" to get the colour scheme he wanted
