Silly issue, not seen this one, but I dug the Board out, it has an XP2500 on it, so I built it up cos the 2500 runnsgreat at 200FSB, and sure enough, it works perfectly fine except for one thing...
If I try pressing the power button to power it down, instead of doing that, it resets itself and then the CPU is found at a 100FSB job... In other words as an MP1100 ?
Now, CPUs resorting to this is nothing new, and usually ist a default perhaps showing the Battery is tunning down maybe, and this was my first thought, and even with the Power switch, I had kind of hoped, but no. No different?
It did it with the Mobo out of a case ( i.e quick test before wasting time trying to fit it all together ) and it does it in a case too, its not the switch itself and naturally I have checked this.
I have also re-updated the BIOS and it has not helped at all either.
Im kind of putting it down to the Mobo on its way out, and this would be a shame, but there you go.
Any other clues?
Any other clues?
