Resistance 2 - Open Beta Key Giveaway!!
20 Jun 2005
OcUK
Get over to ign fellas, they are handing out 7000 beta keys for resistance 2 ... first come first served.
I already got mine :D:D
Misleading.
They have 7000 codes. for 60 minutes these are available to ppl who have joined gamespy and downloaded their .NET compatible chat client, then add someone to your list then they send you a code. Whatever is left in 1 hour will be given away hassle free on IGN.
rp2000
rp2000, you cheeky so and so:p ..... sorry for lack of link guys, posting from the ps3.
Just wanted to give you guys a heads up, its the only way left to get into the pal open beta.
But you go to IGN and there's no info apart from being told to install Comrade, which I can't do at work :p So I was franticly looking for a link or something to sign up to! :p
It's not the only way as pre-ordering the game gets you a beta key.
Thanks, rp. (And Needles for bringing it to my attention!) The online campaign is not the same as the single-player story is it?
Wouldn't have thought so, although would not surprise e if they are on subsets of other in game maps/locations etc.
Is the chances of an OcUK 8 player campaign tonight to beat down those pesky Chimera on?
rp2000
uk.ign.com, there's a link there if you are logged in.
I got mine from my pre-order today after the first lot they sent was wrong lol. Ill try and get some extra keys.
Dont forget you can reedem codes straight of psn now
