Hi guys,
A while ago I purchased a second hand 4850 that has been volt modded and custom biosflashed to enable powersaving and a default clock of 780/1000.
Problem is I can't seem to get any drivers working on it apart from 8.7s (which were out when it was originally flashed). If I install the new drivers, it will blackscreen at the end of the installation. If I then reboot, it will blackscreen imediately as windows loads.
I have to go into safemode and remove the driver.
Only thing I can put it down to is the custom bios. I don't know much about them, so I was wondering if anyone knew whether or not this could be the cause of the problem, and how I could go about fixing it.
Cheers
Cheers
