Man of Honour
- 16 May 2005
- Manchester
Only very briefly. There's a script to use the motion/tilting to control the mouse on-screen, but I found it a bit difficult. I'd imagine with the sensor bar hooked up, and using the pointer instead, would work pretty well though. I still occasionally use the Wii, so the sensor bar has stayed in the front room. that, and the connection isn't right either, although the candle trick would work I guess.
Funnily enough, I might end up having to write some proper code stuff for tilt sensing with the Wii remote on PC soon, for a project.
That'd be quite fun to play with - I might do something similar /re the coding
The use I'm actually thinking of is for our media server, which is hooked up to the same lcd tv as the Wii.... So using the IR for mouse control shouldn't be an issue.
Thanks for the info - I'm just reading some guides now to get a better idea of how it all works
