 - 3 Sep 2003
At the moment my system is an AMD Athlon 64 3000+, 2GB ram, GF4 MX440 (which I kept from two upgrades ago - I don't do gaming but it does struggle with many windows open at 1680x1050!), SBLive soundcard and tv tuner card, all housed in a Antec 3700BQE case.  My main use of the computer is photo editing / panorama stitching and light dabbling in 3d graphics.
Looking at my rig if I want a faster CPU then I pretty much need to change everything, so now may be the time to downsize to a smaller case which would fit on the desk rather than bashing my knee off the tower case as it sits under the desk.
Thought about this spec:
hard drive I'd retain from current build, wouldn't need graphics card or sound card as the ASUS M3N78-CM has them onboard?
Quite out touch with current processors so not sure if this would be a reasonable build for my needs?
The other plan I had was to replace the system with a laptop, however it would be hard to get a decent a spec as above for a similar price, plus I don't think I need the portability of a laptop.
AMD Athlon 64 X2 Dual Core 6000 3.10GHz (Socket AM2) - Retail (£70.49)
Silverstone Sugo SG01B Evolution Aluminium Micro-ATX Case - Black (£88.11)
Asus M3N78-CM NVIDIA 8200 Micro ATX (Socket AM2+) PCI-Express DDR2 (£52.86)
Antec EarthWatts 380W PSU Antec EarthWatts 380W PSU (£35.24)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) (£24.66)
Total £271.36
