So do Tesco. A search for "Tesco" returned 200+ threads and 500+ posts.
Exactly very good point
People saying you can't mention this and you can't mention that
People saying you can't mention this and you can't mention that![]()
*shrug* Just trying to help people avoid getting into trouble with the mods. It's sadly the case that sometimes things are acceptable and other times not.
For all I care, people can talk about whatever shops/etc they like.
lol, there is a very real possibility of this forum disappearing up its own *** if it's not careful. T'would be a shame.![]()
No there isn't.
Damn, such an eloquent come-back. I bet k.Jacko is reeling from that one!
Lol.....pwned!!!
i feel violated.........and not in a good way.![]()
Been trying to play this on the pc but it really is unplayable. No floors on the first floor in the school building, cant see into open rooms indoors, game will not load further than the initial meetin with the headmaster....the list goes on. Oh and you cant change any visual settings so the game looks like absolute pants, even if you force AA in CCC.
But maybe that isn't the fault of the developers. Bully's biggest problem is that it's a shoddy port job, rife with technical missteps that wouldn't warrant comment if they weren't so profoundly damaging to the game. Forget to enable vertical sync, and you can forget completing most classes: In some areas, the game runs at rocket speed, making timed button presses all but impossible. Turn the feature on, however, and prepare for framerate drops that make NASDAQ look stable. These problems, coupled with frequent crashes and a persistent drifting mouse bug (remember what used to happen when you'd hold down a control stick while booting up a game?) make just playing Bully a frustrating chore.
Plugged the comp into the hdTV , got the controller ready and guess what didn't work. I had to have an xbox360 controller , this one i have is just as good but no didn't work
Valve said:Starting the game with less RAM seems to be a temporary workaround. Can a couple of you guys with the issue try this:
Launch Msconfig (Start>Run>Msconfig)
Click on the Boot tab. Choose Advanced Options.
Change the Maximum Memory setting to something less than 2000 megabytes. 1500 is a good beginning point
Restart your computer and test the issue.
If you're using XP and seeing the issue, the msconfig will have a Boot.ini tab and then under Advanced, you will need to lower the MAXMEM option.
I know this isn't a permanent fix but it will get you guys playing until Rockstar can patch the game.
