Network Security Tips Please
Status
Not open for further replies.
24 Sep 2007
I have an article on network security to write, so please could I have:
- Your tips for network security.
- The skills required to gain a job in network security, and your thoughts on whether it's a good industry to work in and the types of opportunities available.
- Your thoughts on the state of the UK network security market.
Thanks all.
Thanks all.
Shouldnt you be doing the research into it then yourself? using your own ideas and findings backed up by proper references rather then getting others to simply tell you everything.
A good knowledge of network security comes with knowing best practices for implementations, for example, firewall configurations, standard workstation images, antivirus, spyware software, regular patch management, physical security, user education, and so on.
What you need to do is use your Athens account (given the question I'm assuming you're doing a college/uni course) and go read some journals. I suggest you start with your librarian to point you in the right direction.
Status
