PSU - Good Enough???
1 May 2003
I am having a few issues with my computer recently, as I have added a 4870 GPU. I thought the card was faulty, as I couldn't load up the OS, other than in safe mode, or when I did I kept getting lots of BSOD's. So I sent it back to OcUK, who said the card is working fine. But I am wondering if its my psu that is causing the problems and it just doesn't have enough power for my system :confused:
My system Spec's
Corsair HX 620 PSU
Intel q6600 G0 CPU
Tuniq Tower 120 CPU Cooler
Gigabyte GA-EP45-DQ6 Intel P45 Mobo
4x1GB PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
Gainward ATI Radeon HD 4870 "Golden Sample" 512MB GDDR5
2x Samsung SpinPoint F1 500GB SATA-II 16MB Cache
2x Pioneer DVR-215DBK 20x DVD±RW SATA Dual Layer ReWriter
Audigy 4 Pro Soundcard with External Box
Floppy Drive
Netgear Wireless Card
3x 120mm High performance fans
Several USD devices, G7 mouse, G15 keyboard, Cannon Printer
I am just after some answers and trying to pin point my issues. So any help would be great.
TIA :)
Had a similar problem last week with mine..
Just built a new system -
Q6600
9800GTX+
3 hard drives etc..
When trying to use my original 650W non branded PSU it would boot but power off as soon as i tried to do anything.
Went out and bought a Jeantech 1000w absolute and it has been rock stable since.
There is a power calculator on the asus website, not very accurate but may give you an idea! - http://support.asus.com/PowerSupplyCalculator/PowerSupplyCalculator_right.aspx?SLanguage=en-us
Your PSU is easilly good enough for that spec mysticsniper. Have you made sure the ram voltage is set correctly? You might also need to up the northbridge voltage a tad as your using 4 sticks of ram (I am using 4 sticks but didn't need to up my NB voltage).
Thanks for all the replies, not sure where it leads me though as I have taken out 2 sticks of RAM and my machine has started normally. :confused:
Do you know how much I should up the voltage. I have everything set on default at the moment. Cheers:)
Try .1 / .2 volt and see how you get on.
My Abit IP35 Pro needed 1.41v to run 4 sticks, upgraded to Gigabyte X38 that onlt needed .1v.
Hello mysticsniper, is your Intel Core 2 Quad Q6600 overclocked at all? If it is overclocked, what sort of voltage are you running through it? :)
Ok thanks for that, will give it a crack and see what happens.
No, everything is at stock volts mate.
The default was set at 1.8v. I tried both 1.82 & 1.84 and that didn't help. So at the moment I am running my ram at 1.86v. I have loaded windows and all is looking good so far.
I am going to run a few tests now and see how it pans out.
My concern is that I never had any issues before I brought the 4870? I had an 8800GT previously. I even formatted the hard drive and installed the OS again. So there couldn't be an driver issues. Strange, very strange :confused:
