- 19 Oct 2002
- Shakespeare’s County
Also to the CAD Designer, lets see some calcs for what you design and which standards they conform to, then I will tell you why we check the designs.
KaHn
That logic doesnt work in the Aerospace or Automotive industry Im afraid. You have stress engineers and CAE analysts with designers and draughtsmen forming the other half of the process as the components go through their various design gateways an iterations.
Im not sure there are BS standards for pyrotechnic bonnet hinges? Or air to air refueling probe brackets on composite spars. Generally the centres of competancy or excellence are the method owners aswell as component responsible. Anything done purely on paper wont be accurate or fast enough such is the complexity of the models.
Dont bother with autocad, only time i used it was for shapes of caravan furniture for a CNC operator to use to make a program for his MDF. I think I would have prefered a drawing board, there was no master model oso pointless having it on CAD.
