Goodyear Optigrip
18 Oct 2004
Kent
I was browsing through the Telegraph magazine this morning when I came across an advert for a potentially interesting new tyre design from Goodyear called Optigrip. Apparently, its a specially designed tyre that exposes a different tread compound as it wears down, the idea being that it essentially loses hardly any performance over time and should theoretically have better worn perofrmance than some brand new competitor tyres (albeit,t hey didn't state which ones). Anyone else heard anything about this product yet? I did a quick Google and about the only further information I could find was here, a short review of the tyre.
What do you think....interesting new design, or clever marketing disguised in claims of revolutionary technology?
That *is* interesting...wonder how much they'll cost comapred to F1 Asymmetrics.
Was at fleet services the other day and saw a billboard promoting the "fuel saver" tyre ? how does that work ?
Lower rolling resistance = higher fuel economy.
However as a side affect of this they generally have less grip.
Pretty sure I read recently that they don't have any less grip, it's just a different design.
Of course they have less grip, they are a harder compound.
Stop from 100mph on a set of Michelin Energy Fuel Savers and do the same with a set of Pilot Sport 2's and tell me they dont have less grip.
Fox, be sensible here, comparing a performance tyre to a fuel saver isn't exactly fair though is it. Compare like for like and there's not *that* much difference. The fuel savers on my wife's Saxo run around are the Avon CR322's, and compared to similar tyres of their size/spec the difference in grip is minimal. Hell, Caterham use them for their race series. :)
Coming back off the tangent, the Goodyear looks like an interesting tyre, will await some more independent reviews. :)
Fox, be sensible here, comparing a performance tyre to a fuel saver isn't exactly fair though is it.. :)
Yeah ones biased to grip the other towards rolling resistance. Which kinda makes your statement in post #9 not true doesnt it. Control tyres rarely are the best tyre, in that caterham series if they are used in OEM applications then it means the smaller wallets in the field are better matched to the big boys.
