Fable 2
You mean you can end up inadvertently cheating if you unplug the 360 and ethernet cable then sign on in the future?
Yeah, there is gold cheat where if you change your date on your 360 to sometime in the future, start up Fable 2 and you will get a shedload of cash (depending on if you own any properties), save your game then revert the date back to normal when you sign in on Live and you still have all the gold.
Pretty sure I did and nothing happened, unless I missed the deadline while trying to rack up the 10K in the interface.
You should get a Sword if you do it right. Also the quest stays in your list forever, after you donate a cretain amount you can donate 10k to get the sword again, but really once you have the sword the donations are just useful to get XP (if you have loads of cash).
Currently I own all of Bowerstone and Oakfields. About 12k cash per tick and I have about 700k Gold. (Although I did leave my 360 running for about 6 hours to rack up cash :) )
rp2000
Say I've got no property and no money, where is best to start to start amassing my fortune?
I'm struggling to get into this as much as Fable...
I'm still early on in the quest, I've got loads of money but I'm struggling to get enough reputation points for the monk guy. Just doesn't seem to be an easy way to get any?
I've killed the bandits and posed for a statue.... now what?
anyone else found that after completeing the crusible they are forced to get divorced with their wifes due to the travel distance being so far back that even though they can be very happy with you efore you set back home they divorce you when you get back?
I get the impression that fable was made with NXE hard disk play in mind.
So much disk spinning... i'm certain its wreaked my drive as i keep geting read errors now. :(
Not wrong there. Spins very fast, and a few times the stuff in the distance doesn't load up for me. Sadly I think I will be bored of this by the time NXE comes out on Nov 19th.
rp2000
