if its a sealed system you really shouldnt be topping it up with anything but coolant, if its an older water/antifreeze mix system replace it with proper coolant
It sounds more like his mate did something to the car that involved draining the coolant and just replaced it with plain water, which is why antifreeze needed to be added.
He didn't say it had no coolant, he said it had no antifreeze. You'd notice if it didn't have any coolant, but having no anti freeze, just water in is a bit harder to spot.
Most people use the terms interchangably. I doubt this 'mate' glanced at the expansion tank and said 'I say old bean, the concentration of water to antifreeze looks a bit awry! Best get that sorted pronto'
He will have meant it was low on coolant.
This is why you don't let chumps fiddle with your car.
