STALKER: Clear Sky v1.5.06 Patch IS OUT N ABOUT
Cheers for the heads up, adds Dx10.1 support for ATi cards. :)
EDIT: ATi have also just released another hotfix driver which includes the Dx10.1 performance improvemenets for it.
Yep.
S.T.A.L.K.E.R.: Clear Sky V1.5.06 patch notes:
V1.5.06
Saved games:
1.5.04 and 1.5.05 saved games will be compatible with patch 1.5.06.
Game changes:
- Fixed an error when the wounded guide didn't want to lead the player anywhere.
- Increased the number of items for sell for the trader at the goods market.
- Added the possibility to upgrade SVDm 2 at Freedom's mechanic.
- Fixed game crash upon the attempt to speak with the wounded character.
- Fixed an error, which led to the blocking of the storyline quest completion at Yantar (the door to Sakharov's bunker couldn't be opened).
- Increased the amount of money of the bandits' ********
- Fixed the displacement of the military warehouses on the PDA map.
- Added the possibility to load the last saved game by pressing space bar after the player's death.
Render improvements:
- Added DX10.1 support.
- Added MSAA for alpha-tested objects ("alpha-to-coverage" for DX10.0, custom "alpha-to-coverage" for DX10.1 for better performance, native DX10.1 implementation for better quality).
- Added new quality level for sun-shadows (ultra) for better picture quality.
- Added new min/max shadowmap technique (which takes advantage of DX10.1 when available) allows to speed up high quality sunshafts rendering for top video boards and high resolutions.
- Added high quality sunshafts acceleration for DX9 renderer.
Multiplayer:
- Fixed various game crashes of server and client sections.
- Added the detailed server's statistics.
- Changed the saving of the server online-dump (dump is saved to online_dump.ltx).
- Added the changing of keyboard layout by pressing LCtrl +LShift.
Cheers for that info m8.
Any difference, performance wise with your setup after you have installed the patch?.
To be honest, I've got my install of the game running sweet as a nut just now and I'm just about to enter Limansk.
Don't want to install this latest patch and *break* anything at this late point. :D
How much game is there to explore once the main quest is over? Anyone? Just wondered whether I'd be better off finishing the game then using that mod that allows you to return to the rest of the map or to just leave the main story and explore a bit. TIA
Still waiting for definitive confirmation that this game has been fixed before buying it. I’ll consider it once I have finished Shadow of Chernobyl. At least they’re still patching it :rolleyes:
I found very little bugs running the game on the 1.05.04 patch, the only time I got a bug was when travelling from the forest to the garbage but I fixed that by taking the long way round to a different exit.
I don't have the patch yet as i got Clear Sky through Steam, so ive gota wait for them. :p
No difference here,
Game is still very slow :( maybe im expecting too much from my hardware.
q6600 @ 3.96ghz
4870x2
8gb ram
i am running it at 2560x1600 though, but even with the visual on medium its stuttering all over the place with poor frame rates.
That the 8.10 hotfix drivers aswell, the second set :(
Really is poor.
The original Stalker runs perfectly. Also i play the likes of crysis war, with no issues.
No difference here,
q6600 @ 3.96ghz
4870x2
8gb ram
Really is poor.
Remember that Clear Sky uses an enhanced version of the XRAY engine, so although the original performed perfectly, it's possible that you may need to reduce the screen resolution or some other settings.
Although to be honest, I'm a bit surprised that your having problems on a spec like that. I'm not so bothered about performance, I don't mind reducing the settings if needed as my graphics card is getting on a bit, I do however want to be able to play the game without getting annoyed with various glitches. Some have more than others, I know, so maybe I should just give it a go and see what happens!
No performance improvements?
Very poor show especially when you consider there have been better looking games out the past week that perform 3 times better.
Russian version got revoked due to some issues, currently going back through testing, so could mean its buggered, once its gone throught testing again it will appear on the Official site for download so id hold off for now.
