- 29 Oct 2008
I've signed up to this forum because I've recieved conflicting advice from a) the dudes I chat to on vent (a clan) and a mate who originally built my current pc, regarding which direction to go with upgrading and I'm stuck. First, here are some rough specs..
Intel Core 2 Duo E6300
Conroe
Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
Vista Home Premium 32bit
3 gig RAM (not sure what type) & not sure which mobo...
I've attatched detailed specs reports to this post from cpuz and Everest.
My first plan was just to get a new gfx card. First I looked at the 4870. Then I looked at the 260/280.
I'm not very knowledgeable on building comps at all. A friend built it. He says to me that my mobo doesn't support SLi, so getting two x 260/280/9800GTX is out of the question. After a bit of thinking I decided to go for a 4870x2 (because I do have PCI-E, thus, it is compatible). I'm currently using an nvidia 7900gs.
THEN I'm told by somebody else that the spec of my PC will not take full advantage of the 4870x2, and that I'd be better off upgrading.
- the motherboard
- the processor
- power supply
and getting a cheaper graphics card, e.g. one 4870.
What should I do? I was all ready to go out and shell out £340 for a x2, and now I'm being told I would be better off upgrading the above three components and getting a cheaper card. I'm upgrading because I want to play games like far cry 2 and crysis on very high. I've just shelled out for a 24" monitor.
So any advice would be massively appreciated, because I'm ordering the parts this weekend. Thanks.
http://www.audioscribbler.co.uk/cpuz.txt
http://www.audioscribbler.co.uk/everest.txt
Conroe
- the motherboard
- the processor
- power supply
