Hey boffins of the OcUK forums!
Thinking of upgrading to the currently discounted Powercolor ATI Radeon HD 4850 PCS Extreme 1024MB.
I'm upgrading from an X1950 Pro and so I'm expecting quite a jump in performance.
I believe my 400W PSU should be adequate in powering it (I don't have a lot of other components).
Speaking of other components, my current system is:
Will the 400W PSU spontaneously combust?
Will the system hold back the graphics card?
Would you recommend a slightly cheaper card?
Would you recommend something I haven't mentioned?
(Note – I am attempting to keep this upgrade inexpensive)
Thanks a lot!
- E6600 (still at 2.4GHz)
- 2x1GB (5-5-5-15) I'm thinking of maybe buying 2GB more of the same modules or getting the cheap 4GB OCZ set.
- DFI Infinity 975 GX
Thanks a lot!
