OcUK Halloween Weekend Special Deals - Prices so good they will scare you!
OcUK Staff
17 Oct 2002
OcUK HQ
Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB)
The TWIN2X2048-6400 is a 2048 MByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 5-5-5-12-T1.
Price: £18.99 ex VAT (£22.31 inc VAT)
BUY NOW!
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
OCZ PC2-6400 Platinum Revision 2 is the latest version of the Platinum DDR2-800 Series. The PC2-6400 Platinum Rev. 2 has been re-engineered to turn out heart-pounding 4-4-4 timings with flawless performance and stability and offer lower latencies than standard 800MHz DDR2 memory.
OCZ exclusively developed these modules for the extreme gamer and overclocker to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and enthusiasts.
The new OCZ PC2-6400 Platinum Rev. 2 utilizes the latest OCZ heatspreader design. XTC (Xtreme Thermal Convection) Heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of the award winning OCZ Platinum DDR2 series, the PC2-6400 Platinum Rev. 2 is built with leading edge technology designed and qualified with special selection of premium components to maximize performance in even the most demanding computing environments. OCZ PC2-6400 products are 100% hand-tested to ensure compliance with stringent quality standards. In addition, each member of the OCZ Platinum family is backed by an industry-leading lifetime warranty, toll-free technical support and the exclusive EVP (Extended Voltage Protection) coverage.
With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum Revision 2 edition is a perfect memory upgrade for the latest CPU arrivials.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- OCZ Lifetime Warranty
- 1.9-2.0 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
Price: £19.99 ex VAT (£23.49 inc VAT)
BUY NOW!
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK)
As part of OCZ’s Gold series, the PC2-6400 2GB modules deliver the performance and speed gamers require for today’s graphic-intensive DirectX 10 PC games. At 800MHz, the 2GB Gold Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide excellent memory bandwidth and deliver the best possible gaming and productivity on Vista systems.
All Gold Edition modules are 100% hand-tested for quality assurance and compatibility and feature high quality, gold-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ Gold series module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.1V ± 5% without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- Gold XTC* Heatspreader
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Price: £31.99 ex VAT(£37.59 inc VAT)
BUY NOW!
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB)
The Twin2X4096-6400C5 G is a 4096MByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 5-5-5-18. Corsair’s line of 4GB memory kits are designed for PCs featuring 64-bit operating systems. Please note: Installing 4GB onto PCs with 32-bit operating systems is not advised since 32-bit operating systems do not support 4GB of system memory.
Price: £31.99 ex VAT (£37.59 inc VAT)
BUY NOW!
G.Skill 4GB DDR2 PK PC2-8500C5 (2x2GB) CAS5 Dual Channel Kit (F2-8500CL5D-4GBPK)
G.Skill, the well known extreme performance provider, today announces the new naming rule. It helps the users can distinguish the product specification through the new model name. G.Skill also launches the new DDR2-1066 CL5-5-5-15 4GB memory kit, F2-8500CL5D-4GBPK, with the new naming rule. G.Skill 4GB Kits support both Intel and AMD platforms.
- Package : 4096MB kit (2x2GB) dual channel pack
- CAS Latency : 5-5-5-15 (PC2-8500)
- Test Voltage : 2.0-2.1 V
- Speed : DDR2 1066MHz (PC2-8500)
- Type : 240-pin DDR2
- Error Checking : Non-ECC
- Registered/Unbuffered : Unbuffered
- Quality Control : Comprehensive rigorously tested in pair at dual channel environment
- Warranty : Lifetime
Price: £61.99 ex VAT (£72.84 inc VAT)
BUY NOW!
Asus GeForce 9800 GTX+ "Dark Knight" 512MB GDDR3 HDTV/DVI (PCI-Express) - Retail
In order to cater to users who require excellent graphical performance boosts and exceptional cooling from their graphic cards, ASUS, world-leading producer of top quality graphic solutions, has today introduced a range of self-designed version graphics cards comprising the latest EAH4870 DK and EN9800GTX+ DK Series. These ASUS designed graphics cards will come equipped with the Dark Knight Fansink that delivers extreme cooling and low noise-levels—greatly enhancing gaming enjoyment. The inclusion of the EMI Shield, DIP Spring Chokes, LF PAK MOS, and Japan-made Solid Capacitors will allow users extreme performance and peace of mind at the same time; and furthermore, users will enjoy up to 9% performance improvements for gaming experiences with the ASUS EAH4870 DK TOP and EN9800GTX+ DK TOP. The ASUS designed EAH4870 DK and EN9800GTX+ DK Series come equipped with the specially designed Dark Knight Fansink. This innovative fansink is equipped with 4 heatpipes and a large heatsink surface area; and is made of aluminum alloy to deliver extreme cooling while retaining operating levels at only 32dB—almost imperceptible in a quiet room—catering to users who require maximum cooling without excessive fan rotation noise. Keeping in line with ASUS’ Rock Solid promise for quality, the upcoming version of the EAH4870 DK and EN9800GTX+ DK Series will come with several solutions to provide top quality graphic performances. With the EMI shield, 66% EMI Interference can be reduced for more stable signals. The DIP Spring Chokes can also lower temperatures by 5–10°C in comparison with traditional Toroidal Coil Chokes. Additionally, the LF PAK MOS guarantees more efficient power and less heat. On top of all this, the Japan-made Solid Capacitors can lower power loss for more stable operations even under long-term use. Therefore, users will be able to enjoy extreme performance and have peace of mind—only with ASUS EAH4870 DK and EN9800GTX+ DK Series.
- GeForce 9800 GTX+ core running at 738MHz
- Shader Clock Speed of 1836MHz
- 512MB GDDR3 Memory running at 2200MHz
- Enthusiastic 4 Heat-Pipe Dark Knight Cooler
- HDMI output support
- New SmartDoctor
- 256-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Full-throttle gaming at extreme HD resolutions and support for 3-way NVIDIAR SLIR mode
- Full MicrosoftR DirectXR 10, Shader Model 4.0 and PCI ExpressR 2.0 support
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Price: £119.99 ex VAT (£140.99 inc VAT)
BUY NOW!
Dell S2409W 24" Widescreen True HD LCD Monitor - Black
Experience stunning detail and clarity with full High-Definition resolution. Ideal for multimedia entertainment, gaming and productivity. Enjoy the latest movies and blockbusters in their highest resolution available. The glossy black bezel complements most environments and most Dell systems.
- Full HD 1920 x 1080 resolution – Enjoy the latest movies and blockbusters in their highest resolution available.
- 16:9 dynamic aspect ratio – Delivers a Full HD experience seamlessly.
- HDMI – Rapid transfer of high quality video and audio in a pure uncompressed digital state for plug and play simplicity.
- Sleek new design - The glossy black bezel complements most environments and most Dell systems.
- Open multiple applications side by side to maximize your play space and optimize your work streams
- Enjoy cinema-style widescreen dimensions when you watch your favorite movies.
- Help maximize valuable physical space with the slim panel design.
- 1920 x 1080 (True/Full HD) Optimum Resolution
- 16.7 Million Colours
- 1000:1 Contrast Ratio
- 5ms Response Time
- 300 cd/m2 Brightness
- One DVI-D Input
- One Analogue Input
- One HDMI Input
- High Definition (HD)- Everything looks better in HD.
- Warranty : 4 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Price: £174.99 ex VAT (£205.61 inc VAT)
BUY NOW!
Point of View GeForce GTX 280 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Get pulled deeper into the gaming experience than ever before with next generation NVIDIA GeForce GTX 280 GPU. GeForce GTX 280 make games including Unreal Tournament 3, Assassin’s Creed, Call of Duty 4: Modern Warfare and S.T.A.L.K.E.R.: Clear Sky - feel like the real thing. High definition worlds crackle and hum with cinema-quality clarity. Lifelike characters behave with such realistic intensity that your palms sweat and your heart races. Objects react to the forces of nature exactly as nature intended. And with 50% better performance than previous generation graphics processors, you get it all...No lag. No dropped frames. No compromises. Beyond the field of play, the GeForce GTX 280 GPU seamlessly shifts intense processing tasks from the CPU to the GPU. Dive into the latest Blu-ray movie, run the Folding@home protein folding application to help cure diseases, browse your favorite web sites in 3D with PicLens, or transcode video to a personal video player up to 7X faster than the CPU.
- Bus Type: PCI Express 2.0 (Backwards compatible with PCI Express)
- Memory: 1GB (1024MB) GDDR3
- Core Clock: 602MHz
- Shader Clock: 1296MHz
- Memory Data Rate: 2214MHz
- Processor Cores: 240
- Shader Model: 4.0
- Texture Fill Rate: 49.2 Billion/sec.
- Memory Interface: 512-bit
- Memory Bandwidth: 141.7GB/sec.
- API Support: Microsoft DirectX 10 and lower, OpenGL 2.1 and lower for Microsoft Windows
- Display Connectors: 2 Dual-Link DVI-I, HDTV + TV Out
- RAMDACs: Dual 400MHz
- HDCP Capable
- HDMI Capable
- 2-Way & 3-Way NVIDIA SLi Support
- Card Dimensions: 266.7mm x 95.3mm x 38.1mm
- Warranty: 1 Year
- Supplied with Brothers in Arms: Hells Highway Full PC Game
Price: £269.99 ex VAT (£317.24 inc VAT)
BUY NOW!
Oooo good work Gibbo.
I was not planning on doing anything today, but seen as you have posted this and a couple of people on the forums were after one of these I could not resist latching this on.
Zalman Reserator1 v2 Fanless Water Cooling System
The Reserator 1 V2 incorporates Zalmans HCET(High Capacity Extrusion Technique) technology, high efficiency cooling technology, and optimal heat dissipation design for exceptional cooling performance even through natural convection cooling. The Reserator 1 V2 is a fanless water cooling system that unites the functions of a reservoir, radiator, and water pump into one system for easy operation. It is anodized and comes with a custom coolant to prevent corrosion. The new CPU Water Block (ZM-WB4 Gold), VGA Water Block(ZM-GWB3), and the optional Northbridge Water Block(ZM-NWB1) and VGA RAM Water Block (ZM-RWB1) enable the setup of a complete Water Cooling System with excellent performance.
- 100% fanless watercooling unit
- New and improved CPU water block, ZM-WB4 GOLD
- New and improved VGA water block, ZM-GWB3
- New and improved Anti-Corrosion Coolant, ZM-G200
- Northbridge waterblock available separately, ZM-NWB1
- Supplied with quick release couplings and clear tubing
Price: £114.99 ex VAT (£135.11inc VAT)
BUY NOW!
Anyone care to comment as to whether the OCZ or Corsair memory would be better/more reliable?
I'd only be running either at stock settings, so stability at the lowest voltage would be more important than any overclocking ability. Thanks. :)
That OCZ 4GB kit is now the same price it was on last weeks TWO. :p
Oh and since I actually bought that stuff, I can't say it's reliable. Had to RMA it because one of the dimms was faulty. I know I'm not statistically significant, I'm just saying...
*will be peeved if his replacement dimms are faulty too*
Might go for the Corsair then! :D
