After a lot of searching, ive decided to get the MSI P43 NEO F IP43 motherboard for just over £50. Will it be compatible with 4gb Corsair TwinX XMS2 DDR2 PC2-6400(800) 240 pin memory? Also will an E5200 fit in it? I'll post its specs in a minute.
Thanks. I'm a lot wiser now. I feel guilty abandoning AMD.Yes, Intel labeled the lower range Intel Pentium. Link below is the data sheet for the cpu. http://processorfinder.intel.com/details.aspx?sSpec=SLAY7
I'm also considering the Asus P5QL Pro for £59. I'm just so confused regarding the Core2 Duo E5200. Is it just the same as an Intel Pentium E5200?
It'll have to do.That would be a better choice although it has a terrible layout. Just look at where the power sockets are.
Also, could I get a 4850 on both of these boards without it impeding any other slots?
