suggest me ?
Make a program that counts the number of characters in a sentence.
I recommend this because it can be done in many different ways, and is fairly simple to make.
like the computer generates say 4 random numbers in a set order say [1,4,5,6]. You then get X amount of guesses at the sequence and you will be told if you have a right number in the right position, a right number in the wrong position or a wrong number each turn. eg [1,5,4,7] would give 1 correct number in correct position, 2 correct numbers in wrong position and 1 wrong altogether :)
done
the code
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
namespace letter_counters
public partial class Sentence : Form
public Sentence()
InitializeComponent();
string Tlength = "";
int stirTin = 0;
string Count = "";
private void txtbSen_TextChanged(object sender, EventArgs e)
private void btnEnter_Click(object sender, EventArgs e)
Tlength = txtbSen.Text.ToString();
stirTin = System.Convert.ToInt32(Tlength.Length);
Count = stirTin.ToString();
MessageBox.Show(Count);
and the location data
private void InitializeComponent()
this.btnEnter = new System.Windows.Forms.Button();
this.lblSen = new System.Windows.Forms.Label();
this.txtbSen = new System.Windows.Forms.TextBox();
this.SuspendLayout();
// btnEnter
this.btnEnter.Location = new System.Drawing.Point(16, 44);
this.btnEnter.Name = "btnEnter";
this.btnEnter.Size = new System.Drawing.Size(75, 23);
this.btnEnter.TabIndex = 0;
this.btnEnter.Text = "Submit";
this.btnEnter.UseVisualStyleBackColor = true;
this.btnEnter.Click += new System.EventHandler(this.btnEnter_Click);
// lblSen
this.lblSen.AutoSize = true;
this.lblSen.Location = new System.Drawing.Point(13, 13);
this.lblSen.Name = "lblSen";
this.lblSen.Size = new System.Drawing.Size(86, 13);
this.lblSen.TabIndex = 1;
this.lblSen.Text = "Enter Characters";
// txtbSen
this.txtbSen.Location = new System.Drawing.Point(105, 10);
this.txtbSen.Name = "txtbSen";
this.txtbSen.Size = new System.Drawing.Size(594, 20);
this.txtbSen.TabIndex = 2;
this.txtbSen.TextChanged += new System.EventHandler(this.txtbSen_TextChanged);
// Sentence
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
this.ClientSize = new System.Drawing.Size(711, 79);
this.Controls.Add(this.txtbSen);
this.Controls.Add(this.lblSen);
this.Controls.Add(this.btnEnter);
this.Name = "Sentence";
this.Text = "Sentence";
this.ResumeLayout(false);
this.PerformLayout();
#endregion
private System.Windows.Forms.Button btnEnter;
private System.Windows.Forms.Label lblSen;
private System.Windows.Forms.TextBox txtbSen;
any more ideas other than mastermind lol maybe a ikle later :D
done .... did that first, am working on an xml creator now just a simple add text to a listbox then output to an xml file
but heres my calc code
using System;
using System.Data;
using System.Text;
namespace more_forms
public partial class calculator : Form
public calculator()
//Addition Private Function
private void addition(int abox, int bbox)
// setting an int to 0 so that ints a + b can be added and the result shown will be assaigned to this int
int result = 0;
// the addition of a + b shoiwn in int result
result = abox + bbox;
//displaying the information of the calculation then converting it into a text and assaigning it a string to display
lblttl.Text = result.ToString();
//Subtract Private Function
private void subtraction(int abox, int bbox)
int result = 0;
result = abox - bbox;
//Multiplication Private Function
private void multiplication(int abox, int bbox)
int result = 0;
result = abox * bbox;
//Division Private Function
private void division(int abox, int bbox)
int result = 0;
result = abox / bbox;
private void Form2_Load(object sender, EventArgs e)
//Addition Button
private void btnAdd_Click(object sender, EventArgs e)
//naming the int's that the data is eventualy going to be converted to
int firstbox = 0;
int secondbox = 0;
//this is trying a function then if not it will catch the rest and siplay something else
try
//this is converting the text (string) from txtAd1 to an int so the calculation can be done in a different function all this click is doing is slecting a seperate function
firstbox = System.Convert.ToInt32(txtAd1.Text);
secondbox = System.Convert.ToInt32(txtAd2.Text);
lblInf.Text = "Completed MOFO!";
catch
lblInf.Text = "ERROR";
addition(firstbox, secondbox);
//Subtraction Button
private void btnsubb_Click(object sender, EventArgs e)
int firstbox = 0;
int secondbox = 0;
try
lblInf.Text = "Everything is A OK";
catch
lblInf.Text = "Uh oh";
subtraction(firstbox, secondbox);
//Multiplication Button
private void btnmulti_Click(object sender, EventArgs e)
int firstbox = 0;
int secondbox = 0;
try
lblInf.Text = "Success!";
catch
lblInf.Text = "Ooops Error!";
multiplication(firstbox, secondbox);
//Division Button
private void btndiv_Click(object sender, EventArgs e)
int firstbox = 0;
int secondbox = 0;
try
lblInf.Text = "Sucess";
catch
lblInf.Text = "Something is wrong!";
division(firstbox, secondbox);
and where everything is located
this.txtAd1 = new System.Windows.Forms.TextBox();
this.txtAd2 = new System.Windows.Forms.TextBox();
this.lblttl = new System.Windows.Forms.Label();
this.lblCalc = new System.Windows.Forms.Label();
this.lblInf = new System.Windows.Forms.Label();
this.btnAdd = new System.Windows.Forms.Button();
this.btnsubb = new System.Windows.Forms.Button();
this.btnmulti = new System.Windows.Forms.Button();
this.btndiv = new System.Windows.Forms.Button();
// txtAd1
this.txtAd1.Location = new System.Drawing.Point(94, 12);
this.txtAd1.Name = "txtAd1";
this.txtAd1.Size = new System.Drawing.Size(100, 20);
this.txtAd1.TabIndex = 0;
// txtAd2
this.txtAd2.Location = new System.Drawing.Point(94, 38);
this.txtAd2.Name = "txtAd2";
this.txtAd2.Size = new System.Drawing.Size(100, 20);
this.txtAd2.TabIndex = 1;
// lblttl
this.lblttl.AutoSize = true;
this.lblttl.Location = new System.Drawing.Point(140, 72);
this.lblttl.Name = "lblttl";
this.lblttl.Size = new System.Drawing.Size(0, 13);
this.lblttl.TabIndex = 2;
// lblCalc
this.lblCalc.AutoSize = true;
this.lblCalc.Location = new System.Drawing.Point(27, 72);
this.lblCalc.Name = "lblCalc";
this.lblCalc.Size = new System.Drawing.Size(84, 13);
this.lblCalc.TabIndex = 3;
this.lblCalc.Text = "Final Calculation";
// lblInf
this.lblInf.AutoSize = true;
this.lblInf.Location = new System.Drawing.Point(124, 117);
this.lblInf.Name = "lblInf";
this.lblInf.Size = new System.Drawing.Size(0, 13);
this.lblInf.TabIndex = 4;
// btnAdd
this.btnAdd.Location = new System.Drawing.Point(13, 176);
this.btnAdd.Name = "btnAdd";
this.btnAdd.Size = new System.Drawing.Size(75, 23);
this.btnAdd.TabIndex = 5;
this.btnAdd.Text = "Add";
this.btnAdd.UseVisualStyleBackColor = true;
this.btnAdd.Click += new System.EventHandler(this.btnAdd_Click);
// btnsubb
this.btnsubb.Location = new System.Drawing.Point(13, 205);
this.btnsubb.Name = "btnsubb";
this.btnsubb.Size = new System.Drawing.Size(75, 23);
this.btnsubb.TabIndex = 6;
this.btnsubb.Text = "Subtraction";
this.btnsubb.UseVisualStyleBackColor = true;
this.btnsubb.Click += new System.EventHandler(this.btnsubb_Click);
// btnmulti
this.btnmulti.Location = new System.Drawing.Point(198, 176);
this.btnmulti.Name = "btnmulti";
this.btnmulti.Size = new System.Drawing.Size(82, 23);
this.btnmulti.TabIndex = 7;
this.btnmulti.Text = "Multiplication";
this.btnmulti.UseVisualStyleBackColor = true;
this.btnmulti.Click += new System.EventHandler(this.btnmulti_Click);
// btndiv
this.btndiv.Location = new System.Drawing.Point(198, 204);
this.btndiv.Name = "btndiv";
this.btndiv.Size = new System.Drawing.Size(82, 23);
this.btndiv.TabIndex = 8;
this.btndiv.Text = "Division";
this.btndiv.UseVisualStyleBackColor = true;
this.btndiv.Click += new System.EventHandler(this.btndiv_Click);
// Form2
this.ClientSize = new System.Drawing.Size(292, 266);
this.Controls.Add(this.btndiv);
this.Controls.Add(this.btnmulti);
this.Controls.Add(this.btnsubb);
this.Controls.Add(this.btnAdd);
this.Controls.Add(this.lblInf);
this.Controls.Add(this.lblCalc);
this.Controls.Add(this.lblttl);
this.Controls.Add(this.txtAd2);
this.Controls.Add(this.txtAd1);
this.Name = "Form2";
this.Text = "Form2";
this.Load += new System.EventHandler(this.Form2_Load);
#endregion
private System.Windows.Forms.TextBox txtAd1;
private System.Windows.Forms.TextBox txtAd2;
private System.Windows.Forms.Label lblttl;
private System.Windows.Forms.Label lblCalc;
private System.Windows.Forms.Label lblInf;
private System.Windows.Forms.Button btnAdd;
private System.Windows.Forms.Button btnsubb;
private System.Windows.Forms.Button btnmulti;
private System.Windows.Forms.Button btndiv;
I quite like this, we say a little project and he runs off and comes back with it.
my xml creator
basically all functions I could think of and make it into an xml doc.
Code:
using System;
using System.Data;
using System.Text;
using System.IO;
using System.Xml;
namespace new_write_xml
    public partial class Form1 : Form
        //strings needed for the program
        string filename = "";
        bool pass = false;
        string comboS = "";
        string combFav = "";
        string totalDest = "";
        public Form1()
        //creating the file name and validating it
        private void btnsub_Click(object sender, EventArgs e)
            filename = txtbFName.Text.ToString();
            //checks if nothing has been enterd
            if (filename == "")
                MessageBox.Show("please enter a file name ");
                //creates the statement of false so the user cannot progress to the next level
                pass = false;
            // if the file then has words inputted into the text box it will then go to the following statements
            else
                //checks if the file exists
                if (!File.Exists(@"C:\XML\" + filename + ".xml"))
                    MessageBox.Show("File Not In Existance, however its now been created");
                    //creates an xml file
                    //XmlTextWriter writer = new XmlTextWriter(@"C:\XML\" + filename + ".xml", new System.Text.ASCIIEncoding());
                    pass = true;
                else
                    MessageBox.Show("File Already Exists! please create another");
                    pass = false;
        //submitting the data to the xml document
        private void button1_Click(object sender, EventArgs e)
            //try and catch stop the error in progress for instance symbols in the file name
            try
                // if the bool pass variable has been changed then it will allow the submit
                totalDest = @"C:\XML\" + filename + ".xml";
                if (pass == true)
                    //this is where the document is created
                    //gives the format of encoding
                    XmlTextWriter writer = new XmlTextWriter(totalDest, new System.Text.ASCIIEncoding());
                    writer.Formatting = Formatting.Indented;
                    writer.Indentation = 4;
                    writer.WriteStartDocument();
                    //opening tags
                    writer.WriteStartElement("OpenXML");
                    //this is an if statement to select if the participant is over 18, through radio buttons
                    if (rbYes.Checked)
                        writer.WriteElementString("OVER18", "Yes");
                        //MessageBox.Show("your over 18");
                    else
                        writer.WriteElementString("OVER18", "No");
                        //MessageBox.Show("your not over 18");
                    //putting the combo box that contains the fave drink to text
                    combFav = cbFav.Text.ToString();
                    writer.WriteElementString("FavDrink", combFav);
                    //MessageBox.Show(combFav);
                    //track bar status less than 5
                    if (tbLike.Value < 5)
                        writer.WriteElementString("LikeDrink", "You dont like " + combFav + "very much");
                        // MessageBox.Show("you dont like " + combFav + " very much");
                    //track bar status more than 5
                    if (tbLike.Value > 5)
                        writer.WriteElementString("LikeDrink", "You think " + combFav + "is amazing!");
                        //MessageBox.Show("you think " + combFav + " is amazing");
                    //this goes through the combo box and selects each ticked and sends it to a string INDIVIDUALY not all together
                    writer.WriteStartElement("Drink");
                    for (int i = 0; i < clBooze.Items.Count; i++)
                        if (clBooze.GetItemChecked(i))
                            comboS = clBooze.Items[i].ToString();
                            writer.WriteElementString("", comboS);
                            //MessageBox.Show(comboS);
                    //closing the tags
                    writer.WriteEndElement();
                    writer.Flush();
                    //closeing the writer
                    writer.Close();
                    // if submit to filename desination has been pressed with nothing in etc ....
                else
                    MessageBox.Show("Something is wrong !");
            catch (Exception EX)
                //display whats wrong
                MessageBox.Show(EX.Message);
where everything is
Code:
        /// <summary>
        /// Required designer variable.
        /// </summary>
        private System.ComponentModel.IContainer components = null;
        /// <summary>
        /// Clean up any resources being used.
        /// </summary>
        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
        protected override void Dispose(bool disposing)
            if (disposing && (components != null))
                components.Dispose();
            base.Dispose(disposing);
        #region Windows Form Designer generated code
        /// <summary>
        /// Required method for Designer support - do not modify
        /// the contents of this method with the code editor.
        /// </summary>
            this.groupBox1 = new System.Windows.Forms.GroupBox();
            this.txtbFName = new System.Windows.Forms.TextBox();
            this.btnsub = new System.Windows.Forms.Button();
            this.groupBox2 = new System.Windows.Forms.GroupBox();
            this.rbNo = new System.Windows.Forms.RadioButton();
            this.rbYes = new System.Windows.Forms.RadioButton();
            this.cbFav = new System.Windows.Forms.ComboBox();
            this.groupBox3 = new System.Windows.Forms.GroupBox();
            this.clBooze = new System.Windows.Forms.CheckedListBox();
            this.tbLike = new System.Windows.Forms.TrackBar();
            this.groupBox4 = new System.Windows.Forms.GroupBox();
            this.label2 = new System.Windows.Forms.Label();
            this.label1 = new System.Windows.Forms.Label();
            this.groupBox5 = new System.Windows.Forms.GroupBox();
            this.button1 = new System.Windows.Forms.Button();
            this.groupBox1.SuspendLayout();
            this.groupBox2.SuspendLayout();
            this.groupBox3.SuspendLayout();
            ((System.ComponentModel.ISupportInitialize)(this.tbLike)).BeginInit();
            this.groupBox4.SuspendLayout();
            this.groupBox5.SuspendLayout();
            // groupBox1
            this.groupBox1.Controls.Add(this.txtbFName);
            this.groupBox1.Controls.Add(this.btnsub);
            this.groupBox1.Location = new System.Drawing.Point(12, 12);
            this.groupBox1.Name = "groupBox1";
            this.groupBox1.Size = new System.Drawing.Size(581, 83);
            this.groupBox1.TabIndex = 0;
            this.groupBox1.TabStop = false;
            this.groupBox1.Text = "File Name";
            // txtbFName
            this.txtbFName.Location = new System.Drawing.Point(7, 28);
            this.txtbFName.Name = "txtbFName";
            this.txtbFName.Size = new System.Drawing.Size(568, 20);
            this.txtbFName.TabIndex = 1;
            // btnsub
            this.btnsub.Location = new System.Drawing.Point(7, 54);
            this.btnsub.Name = "btnsub";
            this.btnsub.Size = new System.Drawing.Size(85, 23);
            this.btnsub.TabIndex = 0;
            this.btnsub.Text = "Submit";
            this.btnsub.UseVisualStyleBackColor = true;
            this.btnsub.Click += new System.EventHandler(this.btnsub_Click);
            // groupBox2
            this.groupBox2.Controls.Add(this.rbNo);
            this.groupBox2.Controls.Add(this.rbYes);
            this.groupBox2.Location = new System.Drawing.Point(12, 101);
            this.groupBox2.Name = "groupBox2";
            this.groupBox2.Size = new System.Drawing.Size(121, 83);
            this.groupBox2.TabIndex = 1;
            this.groupBox2.TabStop = false;
            this.groupBox2.Text = "Are Yo Over 18 ?";
            // rbNo
            this.rbNo.AutoSize = true;
            this.rbNo.Location = new System.Drawing.Point(7, 43);
            this.rbNo.Name = "rbNo";
            this.rbNo.Size = new System.Drawing.Size(39, 17);
            this.rbNo.TabIndex = 1;
            this.rbNo.TabStop = true;
            this.rbNo.Text = "No";
            this.rbNo.UseVisualStyleBackColor = true;
            // rbYes
            this.rbYes.AutoSize = true;
            this.rbYes.Location = new System.Drawing.Point(7, 19);
            this.rbYes.Name = "rbYes";
            this.rbYes.Size = new System.Drawing.Size(43, 17);
            this.rbYes.TabIndex = 0;
            this.rbYes.TabStop = true;
            this.rbYes.Text = "Yes";
            this.rbYes.UseVisualStyleBackColor = true;
            // cbFav
            this.cbFav.FormattingEnabled = true;
            this.cbFav.Items.AddRange(new object[] {
            "Stella",
            "Blue WKD",
            "IRON WKD",
            "Vodka & Coke",
            "Jack Daniels",
            "Paint Thinner",
            "Mojo",
            "Skittles",
            "John Smiths",
            "Kronenburg",
            "Fosters",
            "Carling",
            "Magners",
            "Southern Comfort"});
            this.cbFav.Location = new System.Drawing.Point(55, 29);
            this.cbFav.Name = "cbFav";
            this.cbFav.Size = new System.Drawing.Size(321, 21);
            this.cbFav.TabIndex = 2;
            // groupBox3
            this.groupBox3.Controls.Add(this.cbFav);
            this.groupBox3.Location = new System.Drawing.Point(140, 101);
            this.groupBox3.Name = "groupBox3";
            this.groupBox3.Size = new System.Drawing.Size(453, 83);
            this.groupBox3.TabIndex = 3;
            this.groupBox3.TabStop = false;
            this.groupBox3.Text = "Choose a Drink ?";
            // clBooze
            this.clBooze.FormattingEnabled = true;
            this.clBooze.Items.AddRange(new object[] {
            "Absinthe",
            "Brandy",
            "Ameretto",
            "Cognac",
            "Godons Gin",
            "Vat 19",
            "Bacardi Golden Rum",
            "Lambs",
            "Havana Club",
            "Tequila",
            "Baileys",
            "Dooleys",
            "Peach Schnapps",
            "Champagne",
            "Ale",
            "White Wine",
            "Red Whine",
            "Rose",
            "BuksFiz",
            "Kopperburg"});
            this.clBooze.Location = new System.Drawing.Point(6, 19);
            this.clBooze.Name = "clBooze";
            this.clBooze.Size = new System.Drawing.Size(222, 154);
            this.clBooze.TabIndex = 4;
            // tbLike
            this.tbLike.Location = new System.Drawing.Point(17, 30);
            this.tbLike.Name = "tbLike";
            this.tbLike.Size = new System.Drawing.Size(210, 45);
            this.tbLike.TabIndex = 5;
            this.tbLike.Value = 5;
            // groupBox4
            this.groupBox4.Controls.Add(this.label2);
            this.groupBox4.Controls.Add(this.label1);
            this.groupBox4.Controls.Add(this.tbLike);
            this.groupBox4.Location = new System.Drawing.Point(12, 191);
            this.groupBox4.Name = "groupBox4";
            this.groupBox4.Size = new System.Drawing.Size(241, 100);
            this.groupBox4.TabIndex = 6;
            this.groupBox4.TabStop = false;
            this.groupBox4.Text = "How much do you like this drink ?";
            // label2
            this.label2.AutoSize = true;
            this.label2.Location = new System.Drawing.Point(6, 68);
            this.label2.Name = "label2";
            this.label2.Size = new System.Drawing.Size(46, 13);
            this.label2.TabIndex = 9;
            this.label2.Text = "Its Crap!";
            // label1
            this.label1.AutoSize = true;
            this.label1.Location = new System.Drawing.Point(196, 68);
            this.label1.Name = "label1";
            this.label1.Size = new System.Drawing.Size(39, 13);
            this.label1.TabIndex = 6;
            this.label1.Text = "Loads!";
            // groupBox5
            this.groupBox5.Controls.Add(this.clBooze);
            this.groupBox5.Location = new System.Drawing.Point(307, 191);
            this.groupBox5.Name = "groupBox5";
            this.groupBox5.Size = new System.Drawing.Size(237, 186);
            this.groupBox5.TabIndex = 7;
            this.groupBox5.TabStop = false;
            this.groupBox5.Text = "What else do you like ? ";
            // button1
            this.button1.Location = new System.Drawing.Point(12, 427);
            this.button1.Name = "button1";
            this.button1.Size = new System.Drawing.Size(581, 188);
            this.button1.TabIndex = 8;
            this.button1.Text = "Submit!";
            this.button1.UseVisualStyleBackColor = true;
            this.button1.Click += new System.EventHandler(this.button1_Click);
            // Form1
            this.ClientSize = new System.Drawing.Size(605, 627);
            this.Controls.Add(this.button1);
            this.Controls.Add(this.groupBox5);
            this.Controls.Add(this.groupBox4);
            this.Controls.Add(this.groupBox3);
            this.Controls.Add(this.groupBox2);
            this.Controls.Add(this.groupBox1);
            this.Name = "Form1";
            this.Text = "Form1";
            this.groupBox1.ResumeLayout(false);
            this.groupBox1.PerformLayout();
            this.groupBox2.ResumeLayout(false);
            this.groupBox2.PerformLayout();
            this.groupBox3.ResumeLayout(false);
            ((System.ComponentModel.ISupportInitialize)(this.tbLike)).EndInit();
            this.groupBox4.ResumeLayout(false);
            this.groupBox4.PerformLayout();
            this.groupBox5.ResumeLayout(false);
        #endregion
        private System.Windows.Forms.GroupBox groupBox1;
        private System.Windows.Forms.Button btnsub;
        private System.Windows.Forms.TextBox txtbFName;
        private System.Windows.Forms.GroupBox groupBox2;
        private System.Windows.Forms.RadioButton rbNo;
        private System.Windows.Forms.RadioButton rbYes;
        private System.Windows.Forms.ComboBox cbFav;
        private System.Windows.Forms.GroupBox groupBox3;
        private System.Windows.Forms.CheckedListBox clBooze;
        private System.Windows.Forms.TrackBar tbLike;
        private System.Windows.Forms.GroupBox groupBox4;
        private System.Windows.Forms.GroupBox groupBox5;
        private System.Windows.Forms.Button button1;
        private System.Windows.Forms.Label label2;
        private System.Windows.Forms.Label label1;
gone work on that date one :D
How about extending your sentence counter so it can handle input several sentences long. When you have that try counting words too.
