a budget range? if you were happy with the cx300 then youd prob be happy with any of the sennheisers on ocuk and if you have a larger budget then shure ones are awesome' also makes a difference what types of music they are for as to what earphones would be most suited to you
it really all depends on what sort of sound u want from them and how much you want to pay, do you want bass heavy like the cx300's you had or something more bass light
I've got CX300's not really bass heavy tbh, they sure as hell seem to lack treble and loudness though.
They just sound cheap and naff compared to my Koss, which were actually cheaper and blow them away.
really? are you sure you have them in right and is possible depending on where u got them they may not be real. there were lots of fake cx300's floating about on the net
cx300's are bassy and uncontrolled and lack high end and mid range clarity but they arent terrible, for the money i think they about the best there is that said they are cheap as hell but the reviews it gets all over the place tend to be glowing, much like the ones for them in the shop bit
When you can get the Koss for the same price-ish or cheaper than the CX300's (like I did) they are definitely not the best there is.
They really are terrible once you hear better though.
Got my Sony EX85s yesterday; best headphones I've ever owned. Bass is clear, not rumbly like some headphones, highs and middles sound great too.
You can pick up a pair for £13 but I would avoid the bay at all costs because 99.99% of them are fakes.
http://forums.overclockers.co.uk/showthread.php?t=17859806&highlight=ex90+username_VegetarianAhhh omg, when i saw that i had to hunt and i found one for £17.99 figured was close enough
