Transforming XML with XSL
31 Oct 2005
Leeds
Hi there again, should be a quick simple answer to this
I have a PHP page that takes my SQL database and outputs it as an XML file
I then want to transform the XML using XSL, I already have the XSL file
this is my PHP file
<?php
header("Content-type: text/xml");
$host = "mysql4.hehe.com";
$user = "not seeing my pass";
$pass = "not ever";
$database = "nah";
$linkID = mysql_connect($host, $user, $pass) or die("Could not connect to host.");
mysql_select_db($database, $linkID) or die("Could not find database.");
$query = "SELECT * FROM a5168769_cust";
$resultID = mysql_query($query, $linkID) or die("Data not found.");
$xml_output = "<?xml version=\"1.0\"?>\n";
$xml_output .= "<entries>\n";
for($x = 0 ; $x < mysql_num_rows($resultID) ; $x++){
$row = mysql_fetch_assoc($resultID);
$xml_output .= "\t<username>\n";
$xml_output .= "\t\t<username>" . $row['username'] . "</username>\n";
// Escaping illegal characters
$row['text'] = str_replace("&", "&", $row['text']);
$row['text'] = str_replace("<", "<", $row['text']);
$row['text'] = str_replace(">", "&gt;", $row['text']);
$row['text'] = str_replace("\"", "&quot;", $row['text']);
$xml_output .= "\t\t<password>" . $row['password'] . "</password>\n";
$xml_output .= "\t</username>\n";
$xml_output .= "</entries>";
echo $xml_output;
I have the line
<?xml-stylesheet type="text/xsl" href="inn.xsl"?>
I need to include that somewhere in the above PHP script, whereabouts would I place it? Many thanks
echo it just after the header :)
cheers, what am I looking at here
I've tried
echo <?xml-stylesheet type="text/xsl" href="inn.xsl"?> and that doesn't work, I'm assuming because I've used the echo command I need to look at my line of code following it but I don't know how to correctly present it
I'd forgot you'd echoed the xml version part later :o
I've just moved it upwards so you can see what I mean... feel free to place it all into $xml_output
<?php
echo '<?xml version="1.0" encoding="UTF-8"?>\n';
echo '<?xml-stylesheet type="text/xsl" href="inn.xsl"?>\n';
$pass = "not ever";
$database = "nah";
//$xml_output = "<?xml version=\"1.0\"?>\n";
$xml_output = "<entries>\n";
echo $xml_output;
That's assuming you want the browser to render the xml and apply the styling.
If on the other hand you want the server to do it use xslt, e.g. http://devzone.zend.com/article/1302-Using-PHP-and-XSL-to-Transform-XML-into-Web-Content
Can't use XLST on these server's sadly, thats why I'm going down this path...
cheers, when I post that into dreamweaver some of the colours dissapear as if the code is no longer regonised, anyway I saved it and ran it and now I'm getting
Scrap the above
You left a PHP tag in that was a note rather than an actual command, deleted it and got the colours back
Now I'm getting
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
Invalid at the top level of the document. Error processing resource 'http://www.micholden.site50.net/outputocuk.php'. Line...
<?xml version="1.0" encoding="UTF-8"?>\n<?xml-stylesheet type="text/xsl" href="output.xsl"?>\n<br><tabl...
Hmmm could be your xsl stylesheet or a whitespace issue, are you trying this in IE? It might be worth having a quick check with firefox...
What does the xml output look like? and the xsl?
The XML output looks like this when using the orginial code before we started the changes
http://www.micholden.site50.net/outputxml3.php
This is the XSL file
<?xml version="1.0" encoding="ISO-8859-1"?><xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform"><xsl:template match="/">
<html>
<body>
<h2>Latest News</h2>
<table border="1">
<tr bgcolor="#9acd32">
<th align="left">id</th>
<th align="left">username</th><br />
<th align="left">password</th>
</tr>
<xsl:for-each select="entries/username">
<tr>
<td><xsl:value-of select="id"/></td>
<td><xsl:value-of select="username"/></td>
<td><xsl:value-of select="password"/></td>
</tr>
</xsl:for-each>
</table>
</body>
</html>
</xsl:template></xsl:stylesheet>
Firefox gives this error when running the new code
XML Parsing Error: not well-formed
Location: http://www.micholden.site50.net/outputocuk.php
Line Number 1, Column 39:<?xml version="1.0" encoding="UTF-8"?>\n<?xml-stylesheet type="text/xsl" href="output.xsl"?>\n<entries>
Even if we don't get this sorted I really owe you thanks for taking time out to help:D
bah its printing the new line character '\n', silly me :o
<?php
echo '<?xml version="1.0" encoding="UTF-8"?>';
echo '<?xml-stylesheet type="text/xsl" href="inn.xsl"?>';
$pass = "not ever";
$database = "nah";
echo $xml_output;
After running the new code
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
Only one top level element is allowed in an XML document. Error processing resource 'http://www.micholden.site50.net/output...
<script type="text/javascript">
Firefox
XML Parsing Error: junk after document element
Line Number 32, Column 1:<script type="text/javascript">
Looks like this is being caused by the web host inserting a tracking script :(
Not sure I can get around this one...
It's right, you can't have 2 top level elements!
Check you XML and either remove the <script> tag, which the parser is taking as a top level element along with your <entries> element.
Or put a higher level element and change your xsl accordingly.
scratch that then. if the site is putting in tracking scripts I don't know what you can do about it.
Simon
