The New Cases Gallery
My latest just a normal build nothing fancy/
This case does make for tidy cables at the front, back is a complete mess.
since changed cpu block to one of the new ocz ones quite impressed for the price.
YES, finally someone with a 7" Thermaltake Screen !!
Need some info on them mate. Ive read they dont work with Vista 64 bit, can you confirm this or do they work fine?
And are they actually a worthwhile investment :)
heres mine with the water in it
got to wait until christmas for my silverstone ft01b-w
missus is being stubborn
here is my 3 year old jeantech aqua
picked up from a carboot by my mum
officially the worst and ugliest case on the planet
enjoy ;)
cant help on vista 64 bit, only use 32bit, never got touch screen part to work in vista only xp. there are supposed to be new drivers but to be honest I hardly use it so never tried them.
for me a rash waste of money only running 1 mobo in it, so if for instance I watch a film on it you have to sit right in front of it.
so to be any use the pc needs to be turned 45 deg.
may be all right if used for a media centre with 2 boards.
Nothing amazing, but tonight I moved my machine back into my coolermaster cavalier. I have always had a thing for this case I don't know why!
I knew somebody would notice that :p
Yes it is a Jeantech 700 Watt Storm. Very very good power suply IMO. I have used several decent jeantech power supply's over the years and have no trouble what so ever with any of them.
The fan inside my 700Watt Storm is absolutly silent.
And how is it getting power? I plugged the power cable in and removed it and took the picture quickly. The power supply holds power for about 10 seconds, before the LCD turns off. ;)
To be honest with you the display is always hidden as its under the desk but when ever I have managed to look at it while gaming its never displayed more then around 250+ Wats. Thats the machine in my Sig.
If i'm really bored one day I might open up prime95 on each core and start up crysis to max out the CPU & Graphics and then see what it displays. I'm sure it probably wouldnt be much more then 300+.
