Premium 60Gb vs. Elite 120Gb and VGA vs. HDMI ?
18 Oct 2002
Nottingham
Hello,
Just looking for the differences between the 2 xbox 360's
Am i right in thinking its just the size of the hard drive and colour of the units ? and that the elite has a HDMI included ?
Also is there any advantage in using HDMI over VGA cable ??? i find the VGA cable gives a better picture on my TV ?
Thanks Ben :)
The Premium has been re-branded Pro now.
The only difference is as you say, the colour of the unit and the capacity of the hard disk. All Xbox 360s now come with HDMI, but only the Elite has an HDMI cable with it.
think it's just the hdmi cable now that's much different. parents just picked up a 360 with 60GB hard drive and gears of war1 &2 and an extra controller for £199. only thing i'm wanting to buy for it now is the HDMI cable to hook up to my TV
If you pay more than a tenner, you've been ripped off. A digital cable is a digital cable, though some in the Home Entertainment forum will try and tell you otherwise.
For average home setups, the cheaper the better.
Some people think that if you're looking for a really long cable you might want to spend a bit extra, I'm not sure if they're right or wrong as I've never tried it but seems unlikely.
Well, yes, you will need a better quality cable for longer distances, but we're talking 15-20m here. 5m or below nearly anything will do the job just fine.
